Lab 1: Comparison Operators help
I put in the correct number and I got it wrong. I sure my code is correct.
MongoDB Enterprise atlas-yaff2o-shard-0:PRIMARY> db.zips.find({ “pop”: { “$lt” : 1000 }}).count()
**65
Hi @Bret_Thompson,
I can check that you have successfully completed the Lab 1: Comparision operator. :clap:
If you faced any issue while submitting the answer that led to a failed attempt, please let me know and we can set up a private conversation to further discuss the issue without giving away spoilers to other Community members.
Kind Regards,
Sonali
I gave the correct answer after running the query. But it still gives me a wrong answer!!
The correct answer is not 65.
What is the first digit of your answer?
Bret_Thompson obfuscated the real answer so as to not give it to everyone. Thank you Bret.
