Lab 1.1: Install Course Tools and Datasets SOME HELP PLEASE
I’ve chosen the private cluster path, however, my connect string format
doesn’t match with the connect string provided in the lab
I tried, with no success, to reshape my connect string according to “Load File with mongoimport” section from the cloud docs.
Thanks for any help!
I finally managed to import the data to my database, here are my solution:
people.json
mongoimport --uri="mongodb+srv://performance.astr5.mongodb.net/performance" -u=m201_user -p=****** --drop -c=people --file=people.json
restaurants.json
mongoimport --uri="mongodb+srv://performance.astr5.mongodb.net/performance" -u=m201_user -p=****** --drop -c=restaurants --file=restaurants.json
I found everything here:
Hi @Wicleice_Fabio
That’s great you’ve sorted the issue. Good luck with the rest of the course!
Kindest regards,
Eoin
