I was curious how the code for @ObservedResults
handled exceptions when writing and found the following code by clicking “Jump to definition”:
private func write<Value>(_ value: Value, _ block: (Value) -> Void) where Value: ThreadConfined {
let thawed = value.realm == nil ? value : value.thaw() ?? value
if let realm = thawed.realm, !realm.isInWriteTransaction {
try! realm.write {
block(thawed)
} else {
block(thawed)
Is it safe to use try! realm.write
Throws
An NSError if the transaction could not be completed successfully. If block throws, the function throws the propagated ErrorType instead.
What would be an example of a transaction that couldn’t complete (without the block throwing an error)? (Is it simply because of an error while writing to a file)
