Installing problem
I have installed mongo shell successfully, but when i gave the command mongo --no in my command prompt,it is showing a message “mongo is not recognized as an internal or external command,operable program or batch file”.how to solve this?
Hi @Lakshmi_54809,
Did you set the path correctly ?
Are you able to run the mongo --nodb command from the bin directory ?
~ Shubham
yes.Thanks .Actually I am running the command in another directory
