Index covered problem
Covered Queries
Problem:
Given the following indexes:
{ _id: 1 }
{ name: 1, dob: 1 }
{ hair: 1, name: 1 }
db.example.find( { name : { $in : [ “Bart”, “Homer” ] } }, {_id : 0, hair : 1, name : 1} )
No, this query would use the { name: 1, dob: 1 } index, but it is projecting the hair field.
I think this query would use the { hair: 1, name: 1 } index which can cover this query, right or not?
No it will not.
The query part does equality match on name:. So an index with name: as the first field will be used, as written
But it does not cover because the index does not include the field hair:.
{ name:1, hair:1 } would be a better index though and would cover.
{ hair: 1, name: 1 } would cover the query as well IF you add a filter on hair in the query.
indexes are made by the order of field names so your indexes will have name_dob and hair_name. (I forgot the exact naming, but the order remains)
since your query asks only for a name match, mongodb will look for an index starting with name... thus will discard hair_name index and use only name_dob. if no index starts with name..., then it will revert to full search without an index.
however, if you ask for a match with {name:"...", hair:"..."}, the match terms will be re-ordered as {hair:"...", name:"..."}to match the full hair_name index.
