How do I read uncommitted data inside a transaction?
I have (for example) 2 documents in db and 2 processes running in parallel
each process selects a single doc for update.
the select is done as a transaction.
in FindOneAndUpdateAsync the
filter filters documents with field named ‘locked’
and the update adds a field ‘locked’ to the doc
the first process (transaction) succeeds and the second fails with write violation.
for test purposes the transaction is never committed
public async Task<BsonDocument> GetNextAsyncTest(CancellationToken cancellationToken = default)
            try
                ClientSessionOptions sessionOptions = new ClientSessionOptions()
                var session = await mongoCollection.Database.Client.StartSessionAsync(sessionOptions, cancellationToken);
                session.StartTransaction();
                FilterDefinition<BsonDocument> lockedNotExist = Builders<BsonDocument>.Filter.Exists("locked", false);
                var filter = Builders<BsonDocument>.Filter.And(lockedNotExist);
                var update = Builders<BsonDocument>.Update
                    .Set("locked", true);
                var item = await mongoCollection.FindOneAndUpdateAsync<BsonDocument>(session, filter, update, default, cancellationToken);
                if (item != null)
                    return item;
            catch (Exception ex)
            return null;
Hi @Tago - welcome to the community!
I’m not sure what your question is. Can you clarify what you’re trying to accomplish or what is going wrong?
One thing to point out when working with transactions, the docs state: " When using the drivers, each operation in the transaction must be associated with the session. Refer to your driver specific documentation for details." Check out the docs more details and examples.
