I am sure someone has solved this already. If so can you update the .Net documents and provide a reference in the Getting Started notes since using data binding is quite pervasive. Apologies if I missed it if it is there already.
How can I ensure that property updates are being done within a write transaction when objects are using Data Bindings .
Windows C#, WPF with TwoWay bindings.
