Help in initiating Vagrant for M312
I have installed Vagrant version 2.2.19 and VirtualBox version 6.1.32 on my Mac machine (MacOS Monterey version 12.3.1
The install was successful and now I need to initiate my Vagrant environment
I started by using ‘vagrant init’ as my first command
and then when I use ‘vagrant up’, I run into this error below. Please help:
vikas.saini@M-FVFZF2ZRLYWH ~ % vagrant up
Bringing machine ‘default’ up with ‘virtualbox’ provider…
==> default: Box ‘base’ could not be found. Attempting to find and install…
default: Box Provider: virtualbox
default: Box Version: >= 0
==> default: Box file was not detected as metadata. Adding it directly…
==> default: Adding box ‘base’ (v0) for provider: virtualbox
default: Downloading: base
An error occurred while downloading the remote file. The error
message, if any, is reproduced below. Please fix this error and try
again.
Couldn’t open file /Users/vikas.saini/base
Are you running the command from vagrant-env directory?
I don’t think vagrant init is required
