I have a model like this:
internal class RepositoryItem {
internal RepositoryItem(BsonDocument data, bool locked) {
Id = Guid.NewGuid();
Locked = locked;
if (data != null) {
Data = data;
internal RepositoryItem(JObject data, bool locked)
: this(BsonDocument.Parse(data.ToString()), locked) { }
internal RepositoryItem() { }
public BsonDocument Data { get; set; }
public Guid Id { get; protected set; }
public bool Locked { get; protected set; }
IFindFluent<RepositoryItem, RepositoryItem> CreateQuery(IMongoCollection<RepositoryItem> type, GenericObjectQuery objectQuery) {
var query = type.Find(
string.IsNullOrEmpty(objectQuery.QueryText)
? FilterDefinition<RepositoryItem>.Empty
: Builders<RepositoryItem>.Filter.ElemMatch(i => i.Data, objectQuery.QueryText)); // this does not work if QueryText is something like "{ \"RecordID\": 5 }" considering that RecordID field exists.
if (objectQuery.IsSorted) {
query = objectQuery.SortDirection == SortDirection.Ascending
? query.SortBy(i => i.Data[objectQuery.SortBy])
: query.SortByDescending(i => i.Data[objectQuery.SortBy]);
return query.Skip(objectQuery.Offset).Limit(objectQuery.Limit);
And if objectQuery.QueryText is empty it successfully returns all documents from the collection.
And when the query is not empty, it throws an error: The serializer for field ‘Data’ must implement IBsonArraySerializer and provide item serialization info.
How to make it work?
