Failed to use text index to satisfy $text query (if text index is compound, are equality predicates given for all prefix fields?)
Hello
I have set up a compound index as follows:
db.Capture.createIndex({“Timestamp”: -1, “BodyHtml”: “text”})
Every time a run a query in Compass I get the following error:
failed to use text index to satisfy $text query (if text index is compound, are equality predicates given for all prefix fields?)
The query looks like the following:
{Timestamp: {$gte: new Date(“2021-05-01T00:00:00.000-04:00”)}, $text: {$search: “Session Timeout”}}
What am I missing?
Tom
The query part
is not
Steve
I appreciate your response, but being very new to MongoDb could explain the error a bit more? Also any kind of solution to correct my query?
Tom
You are looking for a range of Timestamp with $gte. If you were looking at a specific Timestamp with $eq the index could be use.
From the query part
I suspect that Session Timeout is the complete value of field. If it is then a normal index might be sufficient.
Since your new to MongoDB, I think it is best that you look at
and take some MongoDB university courses like M201.
