I’m trying to get the first unit test, the one on connection running.
When I run pytest -m connection
from the mflix-python directory, this is the result.
Would you know what’s going on?
========================================================= test session starts ==========================================================
platform linux -- Python 3.10.1, pytest-6.2.5, py-1.11.0, pluggy-1.0.0
rootdir: my_dir, configfile: pytest.ini
collected 43 items / 39 deselected / 4 selected
tests/test_db_connection.py EEEE [100%]
================================================================ ERRORS =================================================================
__________________________________________________ ERROR at setup of test_atlas_setup ___________________________________________________
file my_dir/tests/test_db_connection.py, line 21
@pytest.mark.connection
@pytest.mark.usefixtures('config')
def test_atlas_setup(client, config):
E fixture 'config' not found
> available fixtures: app, cache, capfd, capfdbinary, caplog, capsys, capsysbinary, doctest_namespace, monkeypatch, pytestconfig, record_property, record_testsuite_property, record_xml_attribute, recwarn, tmp_path, tmp_path_factory, tmpdir, tmpdir_factory
> use 'pytest --fixtures [testpath]' for help on them.
my_dir/tests/test_db_connection.py:21
__________________________________________________ ERROR at setup of test_basic_movies __________________________________________________
file my_dir/tests/test_db_connection.py, line 29
def test_basic_movies(client):
E fixture 'client' not found
my_dir/tests/test_db_connection.py:29
_______________________________________________ ERROR at setup of test_search_by_movie_id _______________________________________________
file my_dir/tests/test_db_connection.py, line 36
def test_search_by_movie_id(client):
my_dir/tests/test_db_connection.py:36
_______________________________________________ ERROR at setup of test_simple_text_search _______________________________________________
file my_dir/tests/test_db_connection.py, line 42
def test_simple_text_search(client):
my_dir/tests/test_db_connection.py:42
======================================================== short test summary info ========================================================
ERROR tests/test_db_connection.py::test_atlas_setup
ERROR tests/test_db_connection.py::test_basic_movies
ERROR tests/test_db_connection.py::test_search_by_movie_id
ERROR tests/test_db_connection.py::test_simple_text_search
