How can we edit an array element by index in the aggregation pipeline?
There is a “hack” that you can use with $map
and $range
. For example, let’s say this is input document:
"key": 1,
"array": [
1,
2,
3,
4,
5
Now, let’s say you want to change 3rd element in array
property to 100. You can do it like this:
$map
with$range
- to iterate over indexes from 0 to length ofarray
property, and map its elements -
$cond
with$eq
and$arrayElemAt
- to check if index is equal to the index of element that you want to change. If it is, then change it. If it is not, do nothing.
db.collection.aggregate([
"$set": {
"array": {
"$map": {
"input": {
"$range": [
0,
"$size": "$array"
"in": {
"$cond": [
"$eq": [
"$$this",
2
100,
"$arrayElemAt": [
"$array",
"$$this"
Note: Indexes of array start with 0, so to change 3rd element, we specified index of 2.
You may use dot notation to update directly by index.
mongosh> c.find()
_id: ObjectId("624da543790b00eaacae929e"),
key: 1,
array: [ 1, 2, 3, 4, 5 ]
// change 3rd element to the value 369
mongosh> c.updateOne( { key : 1 } , { $set : { "array.2" : 369 } } )
acknowledged: true,
insertedId: null,
matchedCount: 1,
modifiedCount: 1,
upsertedCount: 0
mongosh> c.find()
key: 1,
array: [ 1, 2, 369, 4, 5 ]
Oops the missing part of my puzzle
I read Edit array element by index and jumped to the conclusion that he wanted to update the document in the database.
Note to self: must read better and completely. B-)
