Hi everyone, I was wondering if the Unity Realm SDK work inside a WebGL build? If so, is there anything else that needs to be done to make it work? Could not find any information online.
No, the Unity SDK does not support web as a target. We should add this to the Unity section as well, but you can see the supported platforms on this page: https://docs.mongodb.com/realm/sdk/dotnet/#std-label-dotnet-intro. The tl;dr is iOS, Android, UWP, Windows, Linux, macOS.
Thank you, is there still a way to make a Unity WebGL instance work with Realm using the Realm Web SDK?
