DBA Exam Path (HELP!)
@SourabhBagrecha
Hello as I had completed My Basic Course I need help with the further courses for The DBA Exam.
In My Courses in DBA Path the next course after the Basic course is M150 Authentication and Authorization as I enrolled for the course and after 2-3 lectures and labs I thought had missed something. I just don’t know that its the correct path or I just have to enroll by the M001 then M100 then M103 and so on. Please Help!
Thanks.
Hi @Harshwardhan_Kurale, thank you for reaching out.
I have forwarded your feedback to the appropriate team, having said that if you feel that you need a little more context on certain things that weren’t introduced/covered in M001, I would highly recommend you to take M103 to learn more about mongod, Sharding & Replication before proceeding with M150.
Also, you don’t need to cover M100 as a pre requisite, but if you are already familiar with SQL databases it would help you in getting a better understanding.
Thanks and Regards.
Sourabh Bagrecha,
Curriculum Services Engineer
but in DBA Path the first one is Authentication and Authorization and the next one is Basic Cluster Management but I started with Authentication and Authorization. what Should I do now?
Hi @Harshwardhan_Kurale, please register for M103 and once you are done with the course you can continue M150.
Thanks and Regards.
Sourabh Bagrecha,
