Create serach index lucene.whitespace for fields in an array
I want to create an index in atlas for some files, and one of them is an array items, with some fileds. This is the json.
  "mappings": {
    "dynamic": false,
    "fields": {
      "client": {
        "analyzer": "lucene.whitespace",
        "searchAnalyzer": "lucene.whitespace",
        "type": "string"
      "items": {
        "dynamic": true,
        "fields": {
          "item1": {
            "type": "string"
          "item2": {
            "type": "string"
        "type": "embeddedDocuments"
      "shipping_code": {
        "type": "string"
I wnand to search for these fields, for this reason I use dynamic: false, so I’ve added this json in atlas search in JSON editor and i don’t get results for item1, item2, for the items of the
array. Is the json ok?, is something missing in the json?
Hi @javier_ga,
Can you provide the following details so that I can better assist:
  1. Several sample document(s) you are searching on
  2. The $search query performed
  3. Expected output based on the sample documents
Jason
already solved, changing “type”: “embeddedDocuments” to “type”: “document”
