Hello,
I get a CORS error when trying to connect to the atlas graphql endpoint
According to @Sumedha_Mehta1 , I would not get the CORS error if i was using the graphql : Mongo Data API and CORS - #4 by Stennie
The error :
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://eu-central-1.aws.realm.mongodb.com/api/client/v2.0/app/application-0-emfej/graphql. (Reason: CORS header ‘Access-Control-Allow-Origin’ missing). Status code: 204.
What are the other possibilities?
has someone got the same issue?
My code :
import React, { useState, useEffect } from "react";
import "./App.css";
import { withAuthenticator } from "@aws-amplify/ui-react";
import Amplify from "aws-amplify";
import awsExports from "./aws-exports";
import '@aws-amplify/ui-react/styles.css';
import { ApolloClient, ApolloProvider, createHttpLink, InMemoryCache, gql } from '@apollo/client';
import { setContext } from '@apollo/client/link/context';
import CreateOrganisation from "./CreateOrganisation"
Amplify.configure(awsExports);
function App({ signOut, user }) {
const httpLink = createHttpLink({
uri: 'https://eu-central-1.aws.realm.mongodb.com/api/client/v2.0/app/application-0-emfej/graphql',
const authLink = setContext((_, { headers }) => {
const token = user.signInUserSession.idToken.jwtToken;
return {
headers: {
'Access-Control-Allow-Origin': '*',
jwtTokenString: token ? `${token}` : "",
const client = new ApolloClient({
link: authLink.concat(httpLink),
cache: new InMemoryCache()
return (
<ApolloProvider client={client}>
<CreateOrganisation />
</ApolloProvider>
export default withAuthenticator(App);
Best regards,
psram
(Ramkumar Pillai)
November 6, 2022, 3:15am
#2
Rather than calling from React Client, you should try calling from Server side NodeJS
or else add Proxy to your web container
for Nginx you can try like this devops-demo/default.conf at master · psramkumar/devops-demo · GitHub
Thank you @psram
I was looking for a built-in solution
I have found in the “app settings” tab → Allowed Request Origins
I was wondering if this could be the built-in solution but i dont succeed to make it work.
Any solution provided in Mongo atlas settings?
Best regards,
Cyril
I have followed @psram suggestion and used his nginx docker container.
Just for other people that may want to do the same thing i let my default.conf file here :
parameters to change :
proxy_set_header Origin
proxy_pass
server {
listen 80;
location /graphql {
proxy_ssl_session_reuse off;
proxy_ssl_server_name on;
proxy_http_version 1.1;
proxy_set_header Origin http://localhost:3001; # the url of my react app
proxy_hide_header Access-Control-Allow-Origin;
add_header Access-Control-Allow-Origin $http_origin;
add_header Access-Control-Allow-Headers *;
proxy_pass https://eu-central-1.aws.realm.mongodb.com/api/client/v2.0/app/application-0-xxx/graphql;
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /usr/share/nginx/html;
As i am working in my laptop using docker. I launch 2 docker containers :
Nginx proxy to access your graphql backend on http://localhost/graphql (instead of https://eu-central-1.aws.realm.mongodb.com/api/client/v2.0/app/application-0-xxx/graphql )
React app on http://localhost:3001
In your react app code you would access the graphql endpoint this way :
uri: 'http://localhost/graphql',
console.log("token",token)
return {
headers: {
...headers,
And you would access your react app through the browser at http://localhost:3001
I hope this will help
Best regards
system
(system)
Closed
December 15, 2022, 6:20pm
#5
