Chapter 4 Lab 2 Querying Arrays and Sub-Documents, Lab question doesn't match IDE question
In Chapter 4 Lab 2 Querying Arrays and Sub-Documents, the Lab Question specifies to search for NEW YORK, whereas the same question in the IDE specifies to search for New York. The capitalization matters and returns different non-zero results. It would help to have consistency between the two!
Hi @April_Liska, thank you for reporting this.
I have updated the same and it should look consistent across labs and IDE.
Thanks and Regards.
Sourabh Bagrecha,
Curriculum Services Engineer
