'm getting this error in my asp.API docker-compose logs
fail: Microsoft.AspNetCore.Diagnostics.DeveloperExceptionPageMiddleware[1]
An unhandled exception has occurred while executing the request.
System.TimeoutException: A timeout occurred after 30000ms selecting a server using CompositeServerSelector{ Selectors = MongoDB.Driver.MongoClient+AreSessionsSupportedServerSelector, LatencyLimitingServerSelector{ AllowedLatencyRange = 00:00:00.0150000 }, OperationsCountServerSelector }. Client view of cluster state is { ClusterId : "1", Type : "Unknown", State : "Disconnected", Servers : [{ ServerId: "{ ClusterId : 1, EndPoint : "Unspecified/catalogcommentdb:27015" }", EndPoint: "Unspecified/catalogcommentdb:27015", ReasonChanged: "Heartbeat", State: "Disconnected", ServerVersion: , TopologyVersion: , Type: "Unknown", HeartbeatException: "MongoDB.Driver.MongoConnectionException: An exception occurred while opening a connection to the server.
---> System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (111): Connection refused 172.24.0.4:27015
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
at MongoDB.Driver.Core.Connections.TcpStreamFactory.Connect(Socket socket, EndPoint endPoint, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Connections.TcpStreamFactory.CreateStream(EndPoint endPoint, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Connections.BinaryConnection.OpenHelper(CancellationToken cancellationToken)
--- End of inner exception stack trace ---
at MongoDB.Driver.Core.Connections.BinaryConnection.Open(CancellationToken cancellationToken)
at MongoDB.Driver.Core.Servers.ServerMonitor.InitializeConnection(CancellationToken cancellationToken)
at MongoDB.Driver.Core.Servers.ServerMonitor.Heartbeat(CancellationToken cancellationToken)", LastHeartbeatTimestamp: "2022-08-08T12:28:13.2001516Z", LastUpdateTimestamp: "2022-08-08T12:28:13.2001518Z" }] }.
at MongoDB.Driver.Core.Clusters.Cluster.ThrowTimeoutException(IServerSelector selector, ClusterDescription description)
at MongoDB.Driver.Core.Clusters.Cluster.WaitForDescriptionChangedHelper.HandleCompletedTask(Task completedTask)
at MongoDB.Driver.Core.Clusters.Cluster.WaitForDescriptionChanged(IServerSelector selector, ClusterDescription description, Task descriptionChangedTask, TimeSpan timeout, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Clusters.Cluster.SelectServer(IServerSelector selector, CancellationToken cancellationToken)
at MongoDB.Driver.MongoClient.AreSessionsSupportedAfterServerSelection(CancellationToken cancellationToken)
at MongoDB.Driver.MongoClient.AreSessionsSupported(CancellationToken cancellationToken)
at MongoDB.Driver.MongoClient.StartImplicitSession(CancellationToken cancellationToken)
at MongoDB.Driver.OperationExecutor.StartImplicitSession(CancellationToken cancellationToken)
at MongoDB.Driver.MongoCollectionImpl`1.UsingImplicitSession[TResult](Func`2 func, CancellationToken cancellationToken)
at MongoDB.Driver.MongoCollectionImpl`1.FindSync[TProjection](FilterDefinition`1 filter, FindOptions`2 options, CancellationToken cancellationToken)
at MongoDB.Driver.FindFluent`2.ToCursor(CancellationToken cancellationToken)
at MongoDB.Driver.IAsyncCursorSourceExtensions.Any[TDocument](IAsyncCursorSource`1 source, CancellationToken cancellationToken)
at MongoDB.Driver.IFindFluentExtensions.Any[TDocument,TProjection](IFindFluent`2 find, CancellationToken cancellationToken)
at CatalogComment.API.Data.CatalogCommentContextSeed.SeedData[T](IMongoCollection`1 productCollection, List`1 seedData) in /src/Services/CatalogComment/CatalogComment.API/Data/CatalogCommentContextSeed.cs:line 9
at CatalogComment.API.Data.CatalogCommentContext..ctor(IConfiguration configuration) in /src/Services/CatalogComment/CatalogComment.API/Data/CatalogCommentContext.cs:line 16
at System.RuntimeMethodHandle.InvokeMethod(Object target, Span`1& arguments, Signature sig, Boolean constructor, Boolean wrapExceptions)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitConstructor(ConstructorCallSite constructorCallSite, RuntimeResolverContext context)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSiteMain(ServiceCallSite callSite, TArgument argument)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitCache(ServiceCallSite callSite, RuntimeResolverContext context, ServiceProviderEngineScope serviceProviderEngine, RuntimeResolverLock lockType)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.VisitScopeCache(ServiceCallSite callSite, RuntimeResolverContext context)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteVisitor`2.VisitCallSite(ServiceCallSite callSite, TArgument argument)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.CallSiteRuntimeResolver.Resolve(ServiceCallSite callSite, ServiceProviderEngineScope scope)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.DynamicServiceProviderEngine.<>c__DisplayClass2_0.<RealizeService>b__0(ServiceProviderEngineScope scope)
at Microsoft.Extensions.DependencyInjection.ServiceProvider.GetService(Type serviceType, ServiceProviderEngineScope serviceProviderEngineScope)
at Microsoft.Extensions.DependencyInjection.ServiceLookup.ServiceProviderEngineScope.GetService(Type serviceType)
at Microsoft.Extensions.DependencyInjection.ActivatorUtilities.GetService(IServiceProvider sp, Type type, Type requiredBy, Boolean isDefaultParameterRequired)
at lambda_method9(Closure , IServiceProvider , Object[] )
at Microsoft.AspNetCore.Mvc.Controllers.ControllerActivatorProvider.<>c__DisplayClass7_0.<CreateActivator>b__0(ControllerContext controllerContext)
at Microsoft.AspNetCore.Mvc.Controllers.ControllerFactoryProvider.<>c__DisplayClass6_0.<CreateControllerFactory>g__CreateController|0(ControllerContext controllerContext)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
--- End of stack trace from previous location ---
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider)
at Microsoft.AspNetCore.Diagnostics.DeveloperExceptionPageMiddleware.Invoke(HttpContext context)
and this is my docker-compose.yml
version: '3.4'
services:
catalogdb:
image: mongo
catalogbranddb:
image: mongo
catalogcategorydb:
image: mongo
catalog.api:
image: ${DOCKER_REGISTRY-}catalogapi
build:
context: .
dockerfile: Services/Catalog/Catalog.API/Dockerfile
catalogbrand.api:
image: ${DOCKER_REGISTRY-}catalogbrandapi
build:
context: .
dockerfile: Services/CatalogBrand/CatalogBrand.API/Dockerfile
catalogcategory.api:
image: ${DOCKER_REGISTRY-}catalogcategoryapi
build:
context: .
dockerfile: Services/CatalogCategory/CatalogCategory.API/Dockerfile
and this is my docker-compose-overider.yml
version: '3.4'
services:
catalogdb:
container_name: catalogdb
restart: always
ports:
- "27017:27017"
volumes:
- ./mongo_data_catalogdb:/data/catalogdb
catalogcategorydb:
container_name: catalogcategorydb
restart: always
ports:
- "27018:27017"
volumes:
- ./mongo_data_catalogcategorydb:/data/catalogcategorydb
catalogbranddb:
container_name: catalogbranddb
restart: always
ports:
- "27019:27017"
volumes:
- ./mongo_data_catalogbranddb:/data/catalogbranddb
catalog.api:
container_name: catalog.api
environment:
- ASPNETCORE_ENVIRONMENT=Development
- "DatabaseSettings:ConnectionString=mongodb://catalogdb:27017"
- "ElasticConfiguration:Uri=http://elasticsearch:9200"
depends_on:
- catalogdb
ports:
- "8000:80"
catalogbrand.api:
container_name: catalogbrand.api
environment:
- "DatabaseSettings:ConnectionString=mongodb://catalogbranddb:27019"
depends_on:
- catalogbranddb
ports:
- "8001:80"
container_name: catalogcategory.api
environment:
- "DatabaseSettings:ConnectionString=mongodb://catalogcategorydb:27018"
depends_on:
- catalogcategorydb
ports:
- "8002:80"
I’m getting this error in all of the APIs Except Catalog.API and only catalog.API worked perfectly and I tried to do everything that I did with Catalog.API but still show error for other services and these are my container
